# Your bucket is already a message queue
Use Tigris object notifications to coordinate AI agents without deploying a message queue. A writer/watcher pattern turns your bucket into an event bus.
Published2026-04-23
Reading10
[Engineering](/blog/tags/engineering/.md)[AI](/blog/tags/ai/.md)[object-storage](/blog/tags/object-storage/.md)+1
* [Webhooks are the 2007 pattern your agents need](#webhooks-are-the-2007-pattern-your-agents-need)
* [The writer/watcher pattern: agents that never talk](#the-writerwatcher-pattern-agents-that-never-talk)
* [Example: content moderation with two agents](#example-content-moderation-with-two-agents)
* [Things that bit me so they don't bite you](#things-that-bit-me-so-they-dont-bite-you)
* [Where else silent agents beat chatty ones](#where-else-silent-agents-beat-chatty-ones)
![Two robots on separate platforms passing a bucket labeled 'MESSAGES' between them via a pulley line, with a colorful cityscape in the background. Robot A sends the bucket while Robot B receives a report.](/blog/assets/images/hero-image-2153ce598b4ac133d45ea52485e5d04a.webp)
Every AI agent is an island. They have their own context window, prompt, tools, and a largely frozen view of the world. The moment you have more than one of them and they need to cooperate you've left "prompt engineering" and walked into the land of distributed systems problems.
This problem is something we've been solving in site reliability for decades: coordinating multiple services that need to hand work back and forth. Ideally you want those services to not have to know or care about each other's existence. When you look through the sacred texts, they dictate that this must be solved with a message queue like RabbitMQ, Kafka, NATS, or SQS. You configure topics, manage consumers, have to think about delivery semantics, and write runbooks for what happens when your broker's disk fills up.
This does work, but it's a whole production system that needs its own monitoring, auth story, scaling plan, and rapidly growing bill at the end of the month. Every time I need to deploy one of them I die a little on the inside.
What if you could cut out the middleman and just use your object storage as your queue? Tigris lets you make your bucket into your queue with [object notifications](https://www.tigrisdata.com/docs/buckets/object-notifications/). These make Tigris send you webhooks when things change so that your agents get alerted instead of having to look in the bucket over and over and over.
## Webhooks are the 2007 pattern your agents need[​](#webhooks-are-the-2007-pattern-your-agents-need "Direct link to Webhooks are the 2007 pattern your agents need")
Webhooks are one of the most simple and enduring patterns on the modern Internet: you give a service a URL and whenever something happens the service sends a POST request to that URL with the payload. Your handler then does whatever it wants with that payload. GitHub uses webhooks to fire off Slack messages for every commit, issue, and opened PR in your repos. Stripe uses them for payment events. Discord, Linear, PagerDuty, half the SaaS-industrial-complex runs on webhooks. They predate Kubernetes, Kafka, and have outlived both REST hype cycles.
Object storage can do the same thing. Configure [a notification rule](https://www.tigrisdata.com/docs/buckets/object-notifications/) on a bucket and you'll get an HTTP `POST` to your endpoint every time an object is created, modified, or deleted. The payload includes the bucket name, key, size, ETag, and timestamp. You can also filter your rules by prefix so a watcher only hears about the keys it actually cares about. You can attach a bearer token so the watcher can verify the call really came from Tigris and not an evil hacker trying to trick your systems into mining Bitcoin or other nefarious deeds.
That's the entire feature. No broker to deploy, no consumer groups to balance, no sacrifices to the dark gods of partition keys. Your storage and your event bus are the same thing.
## The writer/watcher pattern: agents that never talk[​](#the-writerwatcher-pattern-agents-that-never-talk "Direct link to The writer/watcher pattern: agents that never talk")
When you use this in production, you often come up with a writer/watcher pair. One agent does something that writes objects to the bucket, another agent takes those objects to do something useful in reaction. Neither agent knows the other exists. The bucket and notification rule are what binds them together. If you want to add a third downstream agent later, add another notification rule. The original two agents don't need to change.
As an example, let's take a look at a problem that seems like it'd be easy but ends up actually being hard in subtle ways: content moderation. Let's say you're running a social media platform where users can post text with an image attached. Other users can report the posts. The standard pipeline for this is that a user reports a post and that post gets put into a queue for a human moderator to look over and take action from there. This seems simple, but the human moderator is one of the weaker links in the chain. These moderators often work [grueling jobs that make them burn out](https://www.theverge.com/2019/2/25/18229714/cognizant-facebook-content-moderator-interviews-trauma-working-conditions-arizona). It's one of the worst jobs in tech and the industry has a long history of treating the people doing it *terribly*.
AI agents have none of those problems. They don't burn out. They don't need therapy. They're not great at the genuinely hard moderation calls (you should never have them make the final word on a takedown), but they're excellent at the first pass "vibe check": seeing if things are clearly fine, clearly not fine, or an edge case. This kind of filtering can absorb most of the volume of reports and let your human moderators focus on the cases that actually need human judgement.
## Example: content moderation with two agents[​](#example-content-moderation-with-two-agents "Direct link to Example: content moderation with two agents")
The pipeline I built to demonstrate this lives in [tigrisdata-community/agent-coordination-moderation](https://github.com/tigrisdata-community/agent-coordination-moderation):
![Moderation pipeline: a client POSTs to Agent A (Ingest), which calls Claude to classify and writes pending/id.json to Tigris. An object notification fires Agent B (Router), which moves the object to flagged/, needs-review/, or approved/. Flagged items POST to a human review webhook.](data:image/svg+xml;base64,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)
Agent A is the ingest agent. It takes a `POST /submit` with a post ID, the text, and an optional image URL. Imagine this being wired up into an existing report flow as an internal microservice. It then returns HTTP 201 so Tigris keeps chugging along.
In the background, Agent A asks Claude to classify the post against a fixed set of categories (hate speech, spam, NSFW content, harassment, etc) and writes that classification result back to Tigris, triggering an object notification to Agent B.
Agent B is the router agent. It receives notifications from Tigris and then looks at the classification to make a decision:
* If there's no violation, move the record to `approved/`.
* If there's strong confidence of a violation, move it to `flagged/` and `POST` to a human review webhook (Slack, ticket queue, PagerDuty, whatever).
* If there's weak confidence, move it to `needs-review/`.
This "move" is an [atomic rename](https://www.tigrisdata.com/docs/objects/object-rename/) so the object disappears from `pending/` and the watcher's job is done.
Setting up this notification rule is one CLI call:
tigris buckets set-notifications moderation-pipeline \
  --url https://your-router-host.public.domain.here/webhook \
  --token "$WEBHOOK_SECRET" \
  --filter 'WHERE `key` REGEXP "^pending/"'
That's the entire integration. The router only hears about objects under `pending/` so any moves to the other folders don't trigger recursive feedback loops where the router keeps notifying itself forever.
## Things that bit me so they don't bite you[​](#things-that-bit-me-so-they-dont-bite-you "Direct link to Things that bit me so they don't bite you")
Roses have their thorns, here's what bit me while I was working on this example so that you can go into coding battle aware of the tradeoffs.
Object notifications are at-least-once. This is the same deliverability guarantee that SQS gives you: your watcher will get object notifications at least once (but potentially more than once). The router in the demo uses an ETag based deduper and ignores notifications when the object was already moved. Idempotency is not optional here. If your handler isn't truly idempotent, you don't have a working system. You have a system that hasn't broken yet.
Webhook auth isn't optional here. It's tempting to live on the wild side and let just this one hidden endpoint stay hidden, but your watcher endpoint needs to be *public*. If it's public and unauthenticated, anyone can POST whatever they want to it. Tigris notification rules support a bearer token you can verify before doing anything with the payload. The repo has a middleware that's about 10 lines of Go, Claude can translate that into whatever language your app is written in.
If you need to have Tigris retry delivering the webhook, return HTTP status 500. Failure is inevitable and when things fail you really don't want messages to be dropped. In order to tell Tigris to retry sending the webhook later, return a HTTP 500 (internal server error) status and Tigris will retry delivering it up to three times. Don't return 200 if you didn't actually do the work, that's how events get silently dropped at 3 am.
Object ordering is not guaranteed. Notifications can and will arrive out of order. If ordering matters for your use case, please be sure to encode the order into the object key or read the timestamp from the object itself rather than trusting things to be in temporal order.
It's worth noting that none of this is unique to Tigris. These are most of the same constraints you have with any message queue. The win in this case is that you're just writing the producer and the consumer, not having to deal with the sisyphean madness of the infrastructure setup.
## Where else silent agents beat chatty ones[​](#where-else-silent-agents-beat-chatty-ones "Direct link to Where else silent agents beat chatty ones")
Once this pattern clicks with you, you'll see where it can fit everywhere. Here's a few ideas to get you started:
* **Image processing:** Agent A uploads raw photos. Agent B generates thumbnails. Agent C analyzes the images for content policy violations, generates alt-text, or runs OCR across the images. Each stage is independent and you can re-run any stage by retriggering the notification.
* **Document indexing:** Writer agents dump new documents into a bucket. The watcher chunks text, generates embeddings, and writes them to another place in the bucket. Add another agent to keep a knowledge graph in sync.
* **CI artifact distribution:** Your build agents write binaries to Tigris. Deployment agents watch and ship them to staging. Promote to production by copying them to a different prefix that a different agent cares about.
* **Log analysis:** A service writes structured logs to Tigris. An analysis agent watches, runs anomaly detection, and writes alerts somewhere a PagerDuty integration is watching.
* **Multi-step research:** A simulation agent watches, runs experiments, and writes results into Tigris. Synthesis agents can then read those results and roll them up into reports.
The common pattern here is "produce something, react to it". Anything that fits that shape can be built without standing up a queue, deploying a broker, or writing yet another consumer group configuration. All the complexity has been collapsed into a single point: Tigris.
Multi-agent systems get a reputation for being brittle and operationally hairy because of the coordination layer between them. Your queue is its own production system. Your queue's permissions are their own attack surface. Why should they have to be separate from the storage system you're already using? Make your storage coordinate your agents and the whole layer of problems vanishes.
It's less impressive on a slide. It's a lot easier to keep running at 3am.
Ready to connect your agents?
Use Tigris object notifications to coordinate your multi-agent systems without deploying a message queue.
[Read the docs→](https://www.tigrisdata.com/docs/use-cases/agent-coordination/)
[X](https://twitter.com/intent/tweet?text=Check%20out%20this%20post%20on%20the%20%40tigrisdata%20blog%3A%20Your%20bucket%20is%20already%20a%20message%20queue%0A%0A\&url=https%3A%2F%2Fwww.tigrisdata.com%2Fblog%2Fmulti-agent-coordination)[Hacker News](https://news.ycombinator.com/submitlink?u=https%3A%2F%2Fwww.tigrisdata.com%2Fblog%2Fmulti-agent-coordination\&t=Your%20bucket%20is%20already%20a%20message%20queue)[LinkedIn](https://www.linkedin.com/sharing/share-offsite/?url=https%3A%2F%2Fwww.tigrisdata.com%2Fblog%2Fmulti-agent-coordination)[Email](mailto:?subject=Your%20bucket%20is%20already%20a%20message%20queue\&body=Hey!%0A%0ACheck%20out%20this%20article%20on%20the%20Tigris%20blog%3A%20https%3A%2F%2Fwww.tigrisdata.com%2Fblog%2Fmulti-agent-coordination)Copy link
