Blog / Customers
How Parseable Built an Observability Data Lake for AI
· 7 min read
Ty the tiger and Parseable building the observability data lake
Ty the tiger and Parseable building the observability data lake.
Quick Summary5 min read
Unified Observability: Agent behavior, LLM costs, and infrastructure telemetry in a single queryable data lake.
80-90% Compression: All observability data compressed into Parquet format and stored on Tigris object storage.
Smart Caching: Frequently queried data stays hot on local NVMe SSDs, cold data on cheap, scalable object storage.
Natural Language Queries: Go from question to answer without translating between incompatible query languages.
The problem with observability data is there's a lot of it. And most of it isn't useful, except for the precious picks that are actually used in debugging. It's rarely queried, the schema changes frequently as new fields get added, and it's append-only so the data isn't mutated. If you ignore the existing tooling and just look at the shape of the data, observability data looks like data lake data.
Parseable is the data lake for all your observability data. Agent behavior, LLM usage, prompts, tokens, and costs live alongside Kubernetes events and application telemetry, all in the same place. All backed by Tigris object storage.
Why AI observability needs a data lake
When teams first started running AI systems in production, observability seemed like a solved problem. Dashboards, metrics, logs, tracing, alerts. Maybe add another dashboard for token use to make sure you don't have to mortgage the office space, but it all seemed straightforward.
Then unexpected behavior started showing up that didn't neatly line up with a wall of 500s or an outage. An agent still completes tasks, but it takes longer and costs more tokens. A model update subtly changes the output, and downstream services start handling more edge cases. Infrastructure pressure causes intermittent slowdowns, and agent behavior shifts under latency. Nothing obviously crashes, but no one can point to a single metric that explains the change.
As more teams started suffering from this complexity, agent observability platforms were born. Control token usage! Add guardrails for nondeterministic behavior! Better dashboards built for your agents! The real result has been dashboard sprawl, just AI flavored.
What these agent-exclusive platforms deliver is local visibility. You can see what an agent did in a single run and inspect prompts, tool calls, and token counts. Any issue that involves your infrastructure or other services is a pain to correlate across separate tools. And hundreds of agents making thousands of tool calls generate a lot of data to sift through, especially with the rest of your telemetry living somewhere else.
Agent observability cannot happen in isolation while the rest of your observability happens somewhere else. You need visibility across infrastructure.
Nitish TiwariCo-Founder & CEO, Parseable
Nitish Tiwari
Observability data is data lake shaped, and Parseable treats it that way.
The single pane of glass
Traditional observability tooling was built with the assumption that storage was expensive and slow. Data had to be sampled early before storing it, and kept hot on local disks for fast queries and dashboards. By using Tigris object storage, Parseable can store observability data from thousands of agents cheaply, and serve it up for queries instantly.
Parseable takes all this data and lets you query it from a single pane of glass using the easiest language possible: English. Data lake queries start with natural language questions. Translating those into multiple dialects of mutually incompatible query languages is busywork that Parseable cuts out.
The same platform handles LLM observability too: token costs, prompt tracking, and integrations with popular routers like OpenRouter. Your agents, your infrastructure, and your LLM spend all show up in the same interface.
The compute layer that makes it work
A traditional database plans queries against indices and schemata on local disk. Data lakes don't have that luxury. The data arrives via HTTP as JSON, gets written once, and sits in a more latent access tier. You need a compute layer that's smart about what it reads and where it reads from.
Parseable is built in Rust and runs each node as a single binary with no external dependencies. Data flows in via HTTP or Kafka, gets converted to Apache Arrow format in memory, then staged to local disk. A background process asynchronously compresses those Arrow files into columnar Parquet and uploads them to Tigris, achieving 80-90% compression ratios. There is no separate consensus layer. Object storage manages all concurrency control, eliminating complex coordination overhead.
The query engine is built on Apache DataFusion and speaks PostgreSQL-compatible SQL. Instead of scanning every file in storage, it consults a data manifest, a metadata file that tracks which columns and time ranges live in which Parquet files. The query planner uses this manifest to identify exactly which files are relevant, then fetches only the byte ranges it needs from Tigris using the S3 GetRange API. Cold queries hit object storage directly, while hot queries pull from the smart cache.
The smart cache keeps recent Parquet files on local NVMe SSDs on query nodes. A scheduler runs every minute, downloading the most recent data first and working backward. When the cache fills up, the oldest files get evicted automatically. During query execution, the engine checks the cache manifest before making any network calls — if the data is local, it skips the object storage round trip entirely.
Why object storage fits
A traditional observability setup requires a separate tool, storage system, and dashboard for each data type. With Parseable and Tigris, everything flows through a single pipeline.
Traditional Observability
Sources
Ingestion
Storage
Dashboards
K8s Logs
Log Aggregator
Fluentd, Logstash
Search Index
Elasticsearch
Infra Dashboard
App Metrics
Metrics DB
Prometheus, Graphite
Time-Series DB
Local disk
APM Dashboard
Agent Traces
Tracing Backend
Jaeger, Zipkin
Trace Store
Yet another DB
Agent Dashboard
LLM Token Data
LLM Cost Tracker
Custom scripts
Analytics DB
ClickHouse, Postgres
LLM Dashboard
vs.
With Parseable + Tigris
Sources
Ingestion + Cache
Storage
Interface
K8s Logs
App Metrics
Agent Traces
LLM Token Data
Parseable
Unified ingestion
Smart cache + Parquet
SQL + natural language
Tigris
Object storage
Globally distributed
80–90% compression
Single Interface
Natural language queries
Dashboards + alerts
Object storage is the natural fit for observability data. It grows continuously, the more agents you deploy the more data gets created, and at some point you have to decide what to retain. Object storage is massively scalable and cheap, so you can store everything without pre-filtering and query what you need later.
Any S3-compatible object storage could back this architecture, but not all object storage is equal. A single-region provider means your queries are fast in one geography and slow everywhere else. Parseable's compute can move to wherever queries originate, and with Tigris the data is already there waiting. Tigris replicates globally, so Parseable doesn't have to build its own cross-region sync or manage bucket replication rules across providers.
That's what makes the pairing work: Parseable handles compute, Tigris handles storage, and neither has to compensate for the other's limitations.
The whole stack, purpose-built
Observability often gets lumped in with developer tooling, something you set up early alongside your CI pipeline and linter config. In practice, it becomes critical later, when real users hit real problems and you need to understand what happened across your entire stack.
Observability gets bucketed in the dev tools space, but it's not really. It comes much later when you start to get customers. That's when you care about observability.
Nitish Tiwari
Parseable ships ingestion, storage, querying, visualization, and alerting in one package. Purpose-built for observability, not an analytical database you have to assemble into one. If you're Uber or OpenAI, you can set up ClickHouse and customize an analytical database on top of it. Most companies can't, and ClickHouse wrappers fall apart if you care about data sovereignty or control.
Agent behavior, LLM costs, and infrastructure telemetry all live in the same data lake, queryable from a single interface. As the data keeps growing, the observability stack should keep up without asking you to throw anything away.
Build your observability data lake on Tigris
Parseable proves what Tigris can do for observability at scale. Put Tigris behind your own stack and let storage scale with your data.
